dani252
#1 Posted : Wednesday, August 19, 2009 6:21:42 PM(UTC)
dani252
washing machine fills up and agitates well but once it goes to drain it stops completely leaving machine filled with water and it won't drain on any cycle nor will it spin. Trying to figure out what the problem is? Any suggestions?
sidfink43
#2 Posted : Friday, August 21, 2009 6:05:15 AM(UTC)
sidfink43
First thing to try is to by-pass the lid switch. If it works, replace the lid switch.
This site will show you how to do that. On your model you may have plastic trim covering the screws, if so, just gently push the end caps off to access the screws that hold down the console.
Kenmore top loader blues (SublimeMasterJW's Appliance Advice)
Good luck.
Kenmore washer won't drain or spin (Washer Repair)
by jpaw24 11/11/2013 6:40:40 AM(UTC)
by Karen.Smith 3/18/2013 12:01:38 PM(UTC)
kenmore washer won't drain all the way (Washer Repair)
by Dudemeister33 3/11/2012 7:34:22 AM(UTC)
Kenmore washer won't drain (Washer Repair)
by jcconcreteinc1@aol.com 3/3/2012 8:42:21 AM(UTC)
Kenmore washer won't drain, starts spin cycle stops trips circuit breaker (Washer Repair)
by m789h 12/27/2010 1:53:03 PM(UTC)
by NeedsHelp2 9/9/2010 9:52:00 AM(UTC)
by bhatiahn 4/24/2009 4:29:53 PM(UTC)
by stacistephenson 8/15/2008 7:14:37 AM(UTC)
