dmerritt8712
#1 Posted : Monday, March 26, 2012 9:35:58 AM(UTC)
dmerritt8712
Hotpoint DLB3400SBLWH, s/n TL241558H, not sure age of dryer.
Electric dryer will not heat. Checked 5 therostats for continuity, checked heat coil for continuity, all checked zero resistance.
Resistor & board # WE4X799 did not show continuity, replaced it, new resistor does not show continuity either, so I guess it's doing what it was supposed to do, resisting. Wasted $13 and now stumpted.
Any suggestions? Any secret tricks with this model?
#2 Posted : Monday, March 26, 2012 12:41:08 PM(UTC)
The first thing I would do is verify 240 VAC to the dryer. While the motor needs only 120 VAC (one leg) to run, the heating element requires 240 VAC (two legs).
Here are the breakdown diagrams and Replacement parts for General Electric DLB3400SBLWH Electric dryer | AppliancePartsPros.com
Dcraig2102
#3 Posted : Monday, November 9, 2015 5:33:46 AM(UTC)
Dcraig2102
Did you ever figure out the issue because I'm in the same boat?
Dcraig2102
#4 Posted : Monday, November 9, 2015 5:34:20 AM(UTC)
Dcraig2102
HELP! electric dryer will not heat (Dryer Repair)
by jaegray369 3/27/2012 6:31:52 PM(UTC)
Whirlpool Electric Dryer will not heat (Dryer Repair)
by scramjet 8/21/2011 1:25:38 PM(UTC)
Electric Dryer will not heat up (Dryer Repair)
by varn99 6/2/2011 3:26:17 PM(UTC)
by sz9pm3 11/11/2010 3:32:53 PM(UTC)
Electric Dryer will not heat and timer does not count down (Dryer Repair)
by wes_cul 1/26/2010 5:08:31 PM(UTC)
by Eugene P 12/20/2009 10:49:57 AM(UTC)
Electric Dryer will not heat but runs fine! (Dryer Repair)
by dcrenlop 7/19/2009 1:51:32 PM(UTC)
by Shep 4/14/2009 10:37:42 AM(UTC)
by JOYCENAPIER 10/14/2008 12:35:51 PM(UTC)
