Hotpoint DLB3400SBLWH, s/n TL241558H, not sure age of dryer. Electric dryer will not heat. Checked 5 therostats for continuity, checked heat coil for continuity, all checked zero resistance. Resistor & board # WE4X799 did not show continuity, replaced it, new resistor does not show continuity either, so I guess it's doing what it was supposed to do, resisting. Wasted $13 and now stumpted. Any suggestions? Any secret tricks with this model?
Did you ever figure out the issue because I'm in the same boat?
