My electric wall oven was working fine, but after a general power outage it failed. The control panel is dead. There is power in the oven. You can hear the beep every time you depress a key, but no operation. I suspect the oven control board is defective. It this is the problem, how I take it apart? Do I need to remove the oven from the wall to perform the repair? Thanks
THIS FORUM IS DEAD!!!!!!! |
