sandiegan
#1 Posted : Saturday, March 24, 2012 3:37:37 PM(UTC)
sandiegan
My electric wall oven was working fine, but after a general power outage
it failed. The control panel is dead. There is power in the oven. You can hear the beep every time you depress a key, but no operation.
I suspect the oven control board is defective. It this is the problem, how I take it apart? Do I need to remove the oven from the wall to perform the repair? Thanks
#2 Posted : Monday, March 26, 2012 1:44:00 AM(UTC)
Replacement parts for Jenn-Air JMW8530AAB WALLOVEN- S/C MWAVE ELE | AppliancePartsPros.com
It does sound like the control panel is shot.
Here is a manual which should help with the repair, see Page 2-1.
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;down=414
You may have to join the site to download the manual.
I would try flipping the breaker off.on slowly a couple times to see if it will reset.
Also be sure to shut the breaker off when working on the unit.
