Anyone know how to replace a tub bearing kit/ seal kit on this unit? Seal was leaking and during spin cycle tub wasn't spinning unless I push the transmission. Belts were starting to slip. Thanks for any help, Jeff
Originally Posted by: sidfink43  Thanks Sid for the info it worked out beautifully. Machine is working fine. Also I appreciate the recommended parts replacements that the web site suggests. A great help for an old do it yourselfer auto mechanic.
Well thanks, you do the work and we get the credit. Is this a great country or what!
Glad it worked out and thanks for updating us.
