jysylvia
#1 Posted : Sunday, August 16, 2009 1:31:54 PM(UTC)
jysylvia
Anyone know how to replace a tub bearing kit/ seal kit on this unit? Seal was leaking and during spin cycle tub wasn't spinning unless I push the transmission. Belts were starting to slip.
Thanks for any help,
Jeff
sidfink43
#2 Posted : Monday, August 17, 2009 3:44:16 PM(UTC)
sidfink43
Hi Jeff
Here is the service manual which will take you through the process.
http://www.servicematters.com/m...6010373%20(16001145).pdf
Good luck
jysylvia
#3 Posted : Wednesday, August 19, 2009 4:53:02 AM(UTC)
jysylvia
Originally Posted by: sidfink43 Go to Quoted Post
Hi Jeff
Good luck
Thanks Sid for the info it worked out beautifully. Machine is working fine. Also I appreciate the recommended parts replacements that the web site suggests. A great help for an old do it yourselfer auto mechanic.
sidfink43
#4 Posted : Wednesday, August 19, 2009 5:28:00 AM(UTC)
sidfink43
Well thanks, you do the work and we get the credit. Is this a great country or what!
Glad it worked out and thanks for updating us.
jeffrey_benjamin (Refrigerator & Freezer Repair)
by jeffrey_benjamin 7/15/2010 5:56:32 PM(UTC)
jeffrey_benjamin (Washer Repair)
by jeffrey_benjamin 7/3/2010 2:22:43 PM(UTC)
by jeffrey_benjamin 4/24/2010 10:28:34 AM(UTC)
by jeffrey_benjamin 3/5/2010 10:20:55 AM(UTC)
by jeffrey_benjamin 11/18/2009 11:57:32 AM(UTC)
by jeffrey_benjamin 11/9/2009 11:57:46 AM(UTC)
by jeffrey_benjamin 11/9/2009 8:52:21 AM(UTC)
jeff1964 (Washer Repair)
by Jeff1964 4/24/2009 1:24:59 PM(UTC)
Jeffreys oven not heating (Oven Repair (including Ranges and Cooktops))
by Jeffrey Nelson 11/1/2007 7:36:34 PM(UTC)
