Vince
#1 Posted : Saturday, January 12, 2008 10:47:57 AM(UTC)
Vince
We have a viking dual fuel 48´´ range that was installed when we bought the house. The appliance is about 2 years old.
The day before yesterday my wife could not not use the large oven. The small works fine.
None of the 3 resistors are working, the fan and the light are ok. I looked for a temperature safety switch and found one in the back panel that when shunt does not change the situation.
Any suggestion would be more than appreciated.
Thanks in advance.
Vince
Oven does not heat to temperature set (Oven Repair (including Ranges and Cooktops))
by lauract 11/13/2015 12:53:01 PM(UTC)
Oven does not heat up (Oven Repair (including Ranges and Cooktops))
by drpflyers 7/21/2015 1:32:17 PM(UTC)
Oven does not heat past 270 (Oven Repair (including Ranges and Cooktops))
by frostyj50 11/18/2013 6:59:17 PM(UTC)
oven does not heat but stove works control panel works (Oven Repair (including Ranges and Cooktops))
by asfimag 11/10/2012 7:02:45 AM(UTC)
GE True Temp Electric Oven does not heat (Oven Repair (including Ranges and Cooktops))
by ksdavis1121 10/4/2012 11:43:04 AM(UTC)
Frigidaire oven does not heat (Oven Repair (including Ranges and Cooktops))
by camliv 9/30/2012 6:40:11 PM(UTC)
by camliv 9/30/2012 6:35:43 PM(UTC)
by escobedo55 3/11/2012 5:08:15 PM(UTC)
Oven does not heat / elements not working (Oven Repair (including Ranges and Cooktops))
by Steve Dyr59 3/8/2012 3:20:24 AM(UTC)
by davepechkis 12/6/2011 6:50:08 PM(UTC)
by fred08 9/2/2011 3:10:27 AM(UTC)
by smedleybr 7/14/2011 12:01:02 PM(UTC)
by tunnelwise 6/14/2011 12:41:11 PM(UTC)
oven does not heat to correct temp (Oven Repair (including Ranges and Cooktops))
by wawpooh 3/8/2011 11:54:18 AM(UTC)
oven does not heat up (Oven Repair (including Ranges and Cooktops))
by candyburch 2/4/2011 2:33:48 PM(UTC)
