louiers
#1 Posted : Friday, August 14, 2009 8:51:17 AM(UTC)
louiers
hot surface indicator light will not turn off
Frank / APP Team
#2 Posted : Friday, August 14, 2009 9:32:24 AM(UTC)
Frank / APP Team
I'm assuming the top is cooling off.
That is usually caused by the limit switch, which is part of the burner on this model. Below is a picture of a 8" burner, the white device with the rod coming out of it, is the switch I'm referring too. Just using this as a example, I don't know which burner on your range is causing the problem.
Part number: AP2123826
Remove cooktop repair element cycling (Oven Repair (including Ranges and Cooktops))
by gtwassociates 1/2/2010 8:28:28 AM(UTC)
Ge Profile Gas Cooktop Repair (Oven Repair (including Ranges and Cooktops))
by gail56 11/10/2009 8:52:14 PM(UTC)
GE Cooktop Repair (Oven Repair (including Ranges and Cooktops))
by malsims 6/6/2009 7:46:36 AM(UTC)
Electric cooktop repair (Oven Repair (including Ranges and Cooktops))
by loud1123 1/28/2008 3:52:05 AM(UTC)
