2 Pages12>
tops1965
#1 Posted : Friday, March 16, 2012 11:02:10 AM(UTC)
tops1965
My whirlpool dishwasher is not draining (model s62nxplp-7653). I checked the hose and did not find a blockage. When I disconnected the hose from the pump the remaining water drained out so I dont think it is blocked internally. When I push the drain/cancel button the motor hums for a few seconds then clicks and shuts off. I paid $300 for the machine 3 yrs ago and a service call is gonna run me about $250 so I dont think it makes sense to go that route. Any ideas? I really appreciate the help.
John
#2 Posted : Friday, March 16, 2012 6:49:04 PM(UTC)
Hi John,
The model number you posted is incorrect. Verify and repost it please. The name plate should be on the door frame.
tops1965
#3 Posted : Saturday, March 17, 2012 5:49:41 AM(UTC)
tops1965
OK, I think it is DU945PWSQ0. Thanks!
#4 Posted : Saturday, March 17, 2012 3:27:24 PM(UTC)
Very likely the problem is a clogged check valve (the piece where the drain hose is connected to at the pump). It is shown as #15 at the diagram. Unscrew the check valve and check it inside.
- The check valve Part number: AP2910020
tops1965
#5 Posted : Saturday, March 17, 2012 4:26:15 PM(UTC)
tops1965
I did that. The check valve was fine. What alarms me is when I push the cancel/drain button the motor hums for a few seconds, clicks and shuts off without draining any water. Is it possibly the solenoid? Thanks for the help.
#6 Posted : Saturday, March 17, 2012 4:50:40 PM(UTC)
Originally Posted by: tops1965 Go to Quoted Post
...when I push the cancel/drain button the motor hums for a few seconds, clicks and shuts off without draining any water. Is it possibly the solenoid?...
There are no solenoids. The motor has the overload protection which makes such clicking sound.
If there are any water marks on the motor, it had a slow water leak for some time, which caused damage to the motor bearings and/or windings.
If there are no such marks, then remove the top parts from the pump and check for a foreign objects inside and/or broken impellers.
Post the results.
tops1965
#7 Posted: : Saturday, March 17, 2012 6:00:51 PM(UTC)
tops1965
Can I access the top of the pump from inside the machine or do I need to get at it from below?
tops1965
#8 Posted : Saturday, March 17, 2012 6:42:07 PM(UTC)
tops1965
Gene, I was able to take off the pump cover (no14) and the screw and seal (no12) but for the life of me I cant figure how to get the impeller cover off. When I try to turn it with a vice grip it feels like its turning the motor. There must be a hex underneath I need to grip to get it off?
#9 Posted : Monday, March 19, 2012 1:26:39 PM(UTC)
Which part did you call "impeller cover"? Can you refer to the numbers at the diagram?
tops1965
#10 Posted : Monday, March 19, 2012 1:52:46 PM(UTC)
tops1965
That would be no 11.
whirlpool not draining or spinning (Washer Repair)
by bmokie 6/19/2018 1:14:44 PM(UTC)
Whirlpool not draining (Dishwasher Repair)
by thoffland 4/24/2010 10:39:30 PM(UTC)
Whirlpool not draining at end of cycle (Dishwasher Repair)
by mrr4349 4/6/2009 10:06:29 AM(UTC)
2 Pages12>
