My dishwasher is working fine other than it won't drain at the end of the rinse cycle. If I press the cancel/drain button the water will drain but it doesn't drain on its own at the end of the cycle. Any idea what may be causing this?
Appreciate the help!:)
That sounds like the float switch, remove or replace but I was able to clean mine by moving it up and down rapidly, be carefull not to go too far up or too far down...
