mrr4349
#1 Posted : Monday, April 6, 2009 10:06:29 AM(UTC)
mrr4349
My dishwasher is working fine other than it won't drain at the end of the rinse cycle. If I press the cancel/drain button the water will drain but it doesn't drain on its own at the end of the cycle. Any idea what may be causing this?
Appreciate the help!:)
joeruscito
#2 Posted : Sunday, August 9, 2009 12:39:57 PM(UTC)
joeruscito
That sounds like the float switch, remove or replace but I was able to clean mine by moving it up and down rapidly, be carefull not to go too far up or too far down...
