wash will not drain or spin stop after wash cycle thanks for any help
Hi, Check the washer lid switch. You should be able to hear it click on and off as you open and close the lid.
I hae a Whirlpool Heavy Duty Capacity Plus - Supreme 7cycle/2speed washing machine that will wash but it will not drain or spin. It will not go any futher than wash mode. What could be wrong.
Originally Posted by: Bonitas  I hae a Whirlpool Heavy Duty Capacity Plus - Supreme 7cycle/2speed washing machine that will wash but it will not drain or spin. It will not go any futher than wash mode. What could be wrong. Hi, Check the washer lid switch. You should be able to hear it click on and off as you open and close the lid.
I am not really sure who I am writing to but...
... I took the machine apart as it stopped aggitating. I figure it is a belt or gear. I noticed that the motor and gear to the aggitator are enclosed. My question; Is it worth it to take the motor apart to repair the gear or is it cheaper and less frustrating to just buy a new washer?
Hi GeorgeJed
If you post the complete model number of your washer and as a much as possible description of the problem, I might be able to help you.
I am I going to get an answer to my question. How do I remove the gearcase to my washer model no.gsq9364hqo.send to my email. jlrick45@hotmail.com
