prn1955
#1 Posted : 15 years ago
prn1955
I started to replace the drum bearings, the old ones were totally wore off. How are the bearrings positioned, short side toward the door or away from it. Thanks
sidfink43
#2 Posted : 15 years ago
sidfink43
Here is the service manual which will explain how to position them.
http://www.servicematters.com/m...ibrary/docs/16008714.pdf
Good luck
Whirlpool WTW5800BW0 drum bearings? (Washer Repair)
by edw00app 2 years ago
rear drum bearing (Dryer Repair)
by hitmehhh 8 years ago
rear drum bearing (Washer Repair)
by mamageer 11 years ago
changing drum bearing on lg tromm (Washer Repair)
by tfd703 11 years ago
Increasingly Loud GE Dryer - Is a complete Rear Drum Bearing Kit (or more) required? (Dryer Repair)
by Matthew W. 12 years ago
Drum Bearing slide order of installation (Dryer Repair)
by cbishodr 13 years ago
Replacing drum bearings (Washer Repair)
by nagihs 13 years ago
Clothes get hung between drum and front drum bearing (Dryer Repair)
by jackpeg 13 years ago
GE Front Drum Bearing (Dryer Repair)
by Hokiefan 14 years ago
Hotpoint drum bearing glides (Dryer Repair)
by RCoile 14 years ago
Replacing Drum Bearing (Dryer Repair)
by jburski 14 years ago
Front Drum Bearing/Glides (Dryer Repair)
by jrotella 15 years ago
GE dryer drum bearing glides (Dryer Repair)
by kevin ulmer 15 years ago
Dryer Front Drum Bearing Glides (Dryer Repair)
by Robert70 15 years ago
dryer squeals suspect drum bearing (Dryer Repair)
by premech1 15 years ago
