Brandonks
#1 Posted : Thursday, March 8, 2012 5:39:24 PM(UTC)
Brandonks
Just replaced the water level switch. Ran 2 loads of laundry and worked just fine. Turned the timer and pulled the knob out for the third load and nothing happened. Turned the timer to the spin cycle and it spun. So what's wrong? Faulty timer switch or water valve?
Markram
#2 Posted : Friday, March 9, 2012 3:16:24 PM(UTC)
Markram
If you are able to use a voltmeter, test valve for voltage while you have the timer in the "on" postition where water usually enters unit.
If you have 120VAC at the valve, then you know that your timer is sending correct voltage to valve log.
Check all of your connections to see if they are seated properly and ground wires also. Make sure that your hoses are not kinked and valves turned on, and screens cleaned.
If there is no voltage to valve log, then you know that it is most likely the timer. If you can read and Esterline Chart, then refer to that... should be on the technical manual beneath the panel, and find which wire to check on timer, test for voltage at proper time.
Just some thoughts...
A Couple of Problems, Dryer won't Heat / Washer won't fill with water (Washer Repair)
by gregjbutler 2/11/2013 4:14:21 PM(UTC)
washer won't fill with water. (Washer Repair)
by mikeshawver 4/21/2012 9:51:25 AM(UTC)
by colleenrclark 10/16/2011 4:20:46 PM(UTC)
GE Washer won't fill with water (Washer Repair)
by Nikon23 10/13/2011 7:40:41 PM(UTC)
frigidaire front load washer won't fill with water (Washer Repair)
by tponcsak69 8/14/2011 9:29:38 AM(UTC)
by elrodjo 8/6/2010 3:58:05 PM(UTC)
by muleyhunter 8/16/2009 1:44:35 PM(UTC)
Haier Washer won't fill with water (Washer Repair)
by bealcli 7/9/2009 11:19:49 AM(UTC)
Dishwasher won't fill with water (Dishwasher Repair)
by Tru2Chevy 6/26/2009 7:41:16 PM(UTC)
by peco 5/27/2009 8:37:59 AM(UTC)
woman in need of help washer won't fill with water (Washer Repair)
by lindavanzandt 11/30/2008 11:20:23 AM(UTC)
Whirlpool washer won't fill with water (Washer Repair)
by Evonne 10/22/2008 12:52:24 PM(UTC)
by gimpy54 7/1/2008 10:25:11 AM(UTC)
dishwasher won't fill with water (Dishwasher Repair)
by jhmorlang 2/6/2008 8:48:21 AM(UTC)
