Originally Posted by: CHRIS DIETRICH ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Does not operate! With door closed it shows error code F6 and makes a hum noise and emits an oder Chris, the F6 error display indicates and issue with the relay on the control board " F6 Microwave relay failure > Check wiring to Relay 4903 for short circuits.
2.
If wiring is OK, unplug microwave oven or disconnect power. Replace electronic control."
