ECD
#1 Posted : Saturday, March 3, 2012 5:38:08 AM(UTC)
ECD
I have a Thermador PCS366US cooktop which is in need of a replacement ignitor. I can find the part but am not sure how to install it. Is it a difficult lob? Are there any instructions (step-by-step) available?
ATL PETER
#2 Posted : Wednesday, July 29, 2015 11:15:45 AM(UTC)
ATL PETER
Igniter replacement is easy, but Thermador/Bosch stopped making the igniters and the replacement igniters require you to change out the star burner assemblies.
Replacement:
[LIST=1]
  • Remove grate
  • Remove star burner top plate
  • Use a 15/16 box wrench to remove the center brass retaining ring on venturi. Can use the special tool, but a 15/16 box wrench works and can be also turned with a crescent wrench if the ring is stuck
  • Lift the star burner base plate and grasping the clip on the end of the wire, pull the wire off the igniter electrode.
  • On the bottom side of the igniter under the base plate, use needle nose pliers to remove the C-clip that retains the igniter.
  • Pull the igniter electrode out through the top of the base plate.
  • Install new electrode and reassemble in reverse order.[/LIST]
  • Users browsing this topic
    GE Profile Ignitor problems (Oven Repair (including Ranges and Cooktops))
    by Brent Feathers 8/3/2012 8:54:02 AM(UTC)
    ignitor problem (Oven Repair (including Ranges and Cooktops))
    by ljohns 12/14/2011 4:19:39 AM(UTC)
    Another GE gas stovetop ignitor problem (Oven Repair (including Ranges and Cooktops))
    by Jeffdzz 11/4/2011 6:49:24 PM(UTC)
    jenn air ignitor problem (Oven Repair (including Ranges and Cooktops))
    by trotter31 6/22/2011 8:26:06 PM(UTC)
    ignitor problem? (Oven Repair (including Ranges and Cooktops))
    by anolan 9/8/2010 6:58:49 AM(UTC)
    Ignitor Problems (Oven Repair (including Ranges and Cooktops))
    by Johnwilson123 9/16/2009 4:59:15 AM(UTC)
    Ignitor problem (Oven Repair (including Ranges and Cooktops))
    by pnchristie 7/23/2009 1:58:31 PM(UTC)
    Viking broiler ignitor problem (Oven Repair (including Ranges and Cooktops))
    by skidgllfs 3/20/2009 5:36:40 AM(UTC)
    Kitchenaid Ignitor Problem (Oven Repair (including Ranges and Cooktops))
    by wgbiii 1/6/2009 9:37:09 AM(UTC)
    Ge Profile Ignitor Problem (Oven Repair (including Ranges and Cooktops))
    by dakinman 11/24/2008 2:32:02 PM(UTC)
    Bosch stove ignitor problem (Oven Repair (including Ranges and Cooktops))
    by Henry J 11/3/2008 8:52:32 AM(UTC)
    ignitor problem on Thermador cook top (Oven Repair (including Ranges and Cooktops))
    by daneh 3/22/2008 9:04:33 AM(UTC)
