sickappliancerepair
#1 Posted : Sunday, August 2, 2009 7:18:31 PM(UTC)
sickappliancerepair
I have a Miele Dishwasher and need to know where I can get parts for it. Need the Control Board. Dishwasher fills up and will not go into wash mode. drain/fill led flashes. Pump is clear, air gap clear, drain line is clear. Other times machine fills, runs, but will not drain..drai/fill led flashes. I think its a possible control board problem. ANyone knows or has seen this before? Help.....
paulc
#2 Posted : Monday, August 3, 2009 6:26:59 AM(UTC)
paulc
Call Miele at 1-800-999-1360 It's highly unlikely you need an electronic. The service reps will help you diagnose the problem and you can order parts right there on the spot. I suspect you will find an F8 in the fault memory, most likely caused by a flaky heater pressure switch. Good Luck!
need parts (Oven Repair (including Ranges and Cooktops))
by cbarnes70 11/2/2010 2:17:05 PM(UTC)
HELP...Thermador conversion...need parts (Oven Repair (including Ranges and Cooktops))
by mbm280@mindspring.com 7/15/2010 5:10:48 AM(UTC)
Evap Ice buildup-Need parts manual too (Refrigerator & Freezer Repair)
by SSAHVAC guy 3/4/2010 10:43:22 PM(UTC)
Need parts diagram for kenmore washer (Washer Repair)
by timjmix11 12/23/2009 2:23:42 PM(UTC)
Need Parts (Oven Repair (including Ranges and Cooktops))
by LORETTA NEVAREZ 7/10/2009 10:02:29 AM(UTC)
Need parts diagram (Washer Repair)
by richard111 5/26/2009 8:13:08 AM(UTC)
need parts store in Glendale, CA (Dryer Repair)
by MauriS69 11/23/2008 10:45:52 PM(UTC)
Need Parts Diagram for Kenmore 80 series (Washer Repair)
by Vinman 2/8/2008 3:12:01 PM(UTC)
I Need parts numbers for Kenmore dryer (Dryer Repair)
by mishdeme 1/26/2008 1:28:39 PM(UTC)
