I have a Miele Dishwasher and need to know where I can get parts for it. Need the Control Board. Dishwasher fills up and will not go into wash mode. drain/fill led flashes. Pump is clear, air gap clear, drain line is clear. Other times machine fills, runs, but will not drain..drai/fill led flashes. I think its a possible control board problem. ANyone knows or has seen this before? Help.....
Originally Posted by: sickappliancerepair  I have a Miele Dishwasher and need to know where I can get parts for it. Need the Control Board. Dishwasher fills up and will not go into wash mode. drain/fill led flashes. Pump is clear, air gap clear, drain line is clear. Other times machine fills, runs, but will not drain..drai/fill led flashes. I think its a possible control board problem. ANyone knows or has seen this before? Help..... Call Miele at 1-800-999-1360 It's highly unlikely you need an electronic. The service reps will help you diagnose the problem and you can order parts right there on the spot. I suspect you will find an F8 in the fault memory, most likely caused by a flaky heater pressure switch. Good Luck!
