bpimm
#1 Posted : Friday, July 31, 2009 4:03:19 PM(UTC)
bpimm
I'm looking for a wiring diagram for the above mentioned Dryer. Anyone have one they would be willing to share?
I have no heat, I have traced the hot lead to the element through the thermal switches back to the timer. the timer is not powering the element in any mode. I need to see what else can effect the powering of the element.
Brian
sidfink43
#2 Posted : Sunday, August 2, 2009 6:20:32 AM(UTC)
sidfink43
Here is a generic service manual that has a set of generic wiring diagrams.
https://secured.whirlpoo...620794/$FILE/4322260.pdf
I assume you have tested everything for continuity. Notice that you have two "hot" wires going to the heating element, if the one is ok, the problem is in the other.
Good luck.
bpimm
#3 Posted : Sunday, August 2, 2009 9:02:08 AM(UTC)
bpimm
Thanks, that should help.
Yes Both lines are good to the timer, so either the timer is bad or it's not being told to turn on the element, I just need to figure out where the fault is.
Brian
sidfink43
#4 Posted : Sunday, August 2, 2009 10:31:36 AM(UTC)
sidfink43
Try it in all cycles.
The timer is not likely the problem, but as Sherlock Holmes has said, when you have eliminated the impossible, whatever is left, however improbable must be the truth.
Good luck
bpimm
#5 Posted : Sunday, August 2, 2009 11:23:00 AM(UTC)
bpimm
Good luck
Agreed, I have checked in all cycles, I'm assuming it's the temp switch or the circuit board that controls the moisture sensor.
There is a switch on the control panel that is labeled "Extra Care" What does that mean? I don't have the users manual to look up what some marketing geek meant when he came up with such a descriptive label.:)
I should have some time this afternoon to take another look at it.
bpimm
#6 Posted : Sunday, August 2, 2009 3:44:31 PM(UTC)
bpimm
Double post
Need wiring diagram for Duet GHW9150PW1 (Washer Repair)
by Conesus 12/14/2022 10:50:49 AM(UTC)
Need wiring diagram for heating element/thermal fuse/hi-temp fuse forAmana ALE643RAW. (Dryer Repair)
by mdjetdoc 1/13/2016 11:31:57 AM(UTC)
Need Wiring Diagram for Whirlpool Gas Dryer (Dryer Repair)
by ToddErickson 2/2/2015 4:11:08 PM(UTC)
need wiring diagram (Oven Repair (including Ranges and Cooktops))
by fudge2009 4/26/2014 3:49:14 AM(UTC)
by tylerlee 8/10/2013 5:19:23 PM(UTC)
need wiring diagram (Dryer Repair)
by rva-fixit 7/28/2013 6:59:31 AM(UTC)
Need wiring diagram for this refer (Refrigerator & Freezer Repair)
by nan1112 7/26/2013 3:47:47 AM(UTC)
Need wiring diagram (Oven Repair (including Ranges and Cooktops))
by Charliez 12/17/2012 3:26:15 PM(UTC)
Need wiring diagram for GE dryer (Dryer Repair)
by rick88ss 10/22/2012 7:55:10 PM(UTC)
need wiring diagram for magic chef furnace and ac unit with robertshaw gas valve and (Heating, Ventilation, and Air Conditioning (HVAC))
by bigdaddy88 8/2/2012 4:16:30 PM(UTC)
Need wiring diagram (Dryer Repair)
by Rick41 5/1/2012 8:06:34 AM(UTC)
wiring disconnected from timer, need wiring diagram (Dryer Repair)
by Chip65 12/2/2011 2:51:45 PM(UTC)
Need wiring diagram for Kenmore 400 series dryer (Dryer Repair)
by MarthaV 7/15/2011 8:03:59 AM(UTC)
need wiring diagram for fridge (Refrigerator & Freezer Repair)
by misterfixall 5/5/2011 4:55:11 AM(UTC)
Need wiring diagram. Help. (Refrigerator & Freezer Repair)
by justin99 2/25/2011 9:13:19 AM(UTC)
