My wife went to cook a roast the other day,preheated oven 350 ,2 hours later raw roast. I turned off and back on the oven it never got hot. Today I removed the inside bottom and heat spreader turned on the oven and it lit and heated to 350 in about 5 minutes.:confused: Intermittant problem??? Peter
Hi Peter, If you see any of the following problems: a) Oven shuts off during the Bake cycle and food is not
cooked; b) Oven will not light, or will light, and then shut off; c) Oven burner ignition is sporadic; d) Oven may “lockout” after cycling the oven burner at Bake settings; e) Oven cools down after preheat;
then the bake burner has to be replaced.
- The part number for the bake burner assembly is AP3598752
Good luck. Gene.
