washer fills and washes but doesnt go into spin drain cycle ,,,you have to manual turn control knob to spin then pull out again ,,after that it works ,,but i have to manual turn to spin after every load ,,,could this be timer switch ? if so how do you replace it ? besides pulling off back cover are there any tips for replacing timer ,which is what i think it is ,,,thanks steve Norwood Pa
