scubasteve1234
#1 Posted : Wednesday, February 22, 2012 8:36:37 AM(UTC)
scubasteve1234
washer fills and washes but doesnt go into spin drain cycle ,,,you have to manual turn control knob to spin then pull out again ,,after that it works ,,but i have to manual turn to spin after every load ,,,could this be timer switch ? if so how do you replace it ? besides pulling off back cover are there any tips for replacing timer ,which is what i think it is ,,,thanks steve Norwood Pa
ApplianceJunk
#2 Posted : Wednesday, February 22, 2012 10:36:53 AM(UTC)
ApplianceJunk
Yes it could be a faulty timer.
scubasteve1234
#3 Posted : Saturday, February 25, 2012 1:00:03 PM(UTC)
scubasteve1234
The timer was bad. The only couple tricks to replacing timer is prying off the inner cap on timer knob. Once you get that off. Pry and pull white inner locking cap. Reach around back after you unplug timer connection and remove screw. Grasp timer slide it to side and it will pop up and off Place new timer into same spot. And slide it the opposite way. Replace screw plug in connections. Put cover back on washer and plug back in. The way i knew it was the timer was washer. Not going into spin cycle after wash is done washing. I manually had to spin knob to spin and turn back on.
Vintage Maytag washer A612 motor replacement - possible to use single speed motor? (Washer Repair)
by mookie3333 5/3/2024 5:58:32 PM(UTC)
Maytag washer mav6257aww user (Washer Repair)
by Bigredkansan 4/5/2024 6:17:18 PM(UTC)
Maytag washer mav6257aww (Washer Repair)
by Guest 4/5/2024 6:11:48 PM(UTC)
Clicking / creaky sound Maytag Washer (Washer Repair)
by Guest 4/1/2024 7:29:31 AM(UTC)
Maytag Washer Doesn't Complete Spin Cycle (Washer Repair)
by glmoore0001 2/5/2024 6:32:24 AM(UTC)
Maytag Washer MVWP575GW0 strange problem (Washer Repair)
by Macdawgg 11/18/2023 8:07:47 AM(UTC)
Maytag Washer Excess Suds during "clean washer" cycle (Washer Repair)
by DogHair 11/14/2023 2:04:58 PM(UTC)
Top load Maytag washer model Model LA410 with s/n 336623 (Washer Repair)
by Guest 10/26/2023 10:58:17 AM(UTC)
Maytag Washer MAH5500BWQ (Washer Repair)
by Guest 9/10/2023 4:01:49 PM(UTC)
MAYTAG WASHER MODEL MAH5500BWW (Washer Repair)
by Guest 8/21/2023 5:22:03 PM(UTC)
Maytag washer drive motor mount question (Washer Repair)
by Guest 7/29/2023 5:24:40 AM(UTC)
Maytag Washer Rise Cycle (Washer Repair)
by Ollie21 7/5/2023 6:03:49 PM(UTC)
Maytag washer control board burns out (Washer Repair)
by Guest 6/20/2023 2:12:48 PM(UTC)
Maytag Washer Not Draining F9E1 (Washer Repair)
by amappliancewi 6/16/2023 10:44:24 AM(UTC)
MAYTAG WASHER NO GOING INTO SPIN CYCLE (Washer Repair)
by Guest 2/27/2023 8:13:04 AM(UTC)
