Hi - I need help in determining what parts to order to solve this problem. The washer ran fine for two loads, then during the third load several things went wrong. Noticed a strong odor of rubber, and saw that the machine was spinning slowly but still had a lot of water in it and water was leaking on the floor from the edges of the cabinet. It was almost done with the cycle and shut off. I pulled the front panel and saw water dripping out of the tub where the transmission shaft enters. I siphoned about 6 gallons out (to the bottom of the inside tub) and the dripping stopped. I lowered the drain hose to dump the rest of the water and it drained fine. I looked under and the belts still looked ok and it seems like the pump turns ok when I turn the motor pully. The inside of the cabinet has some signs of oil splatter that flung off of the transmission. I assume I need the tub seal and the bearing, and belts just to be sure. Why didn't the water pump out? Do I need a pump or is it something else? Can water leak into the transmission or is it still OK (it has never made any bad noises). Where can I get the instructions on how to replace the seal on the tub? Thank you for your assistance - Kurtis
What could be causing my Maytag washer to leak water?
Laser pointer
Originally Posted by: kaclark7 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi - I need help in determining what parts to order to solve this problem. The washer ran fine for two loads, then during the third load several things went wrong. Noticed a strong odor of rubber, and saw that the machine was spinning slowly but still had a lot of water in it and water was leaking on the floor from the edges of the cabinet. It was almost done with the cycle and shut off. I pulled the front panel and saw water dripping out of the tub where the transmission shaft enters. I siphoned about 6 gallons out (to the bottom of the inside tub) and the dripping stopped. I lowered the drain hose to dump the rest of the water and it drained fine. I looked under and the belts still looked ok and it seems like the pump turns ok when I turn the motor pully. The inside of the cabinet has some signs of oil splatter that flung off of the transmission. I assume I need the tub seal and the bearing, and belts just to be sure. Why didn't the water pump out? Do I need a pump or is it something else? Can water leak into the transmission or is it still OK (it has never made any bad noises). Where can I get the instructions on how to replace the seal on the tub? Thank you for your assistance - Kurtis This page should help Maytag Tub Seal Replacement
