kaclark7
#1 Posted : Monday, February 20, 2012 5:03:39 PM(UTC)
kaclark7
Hi - I need help in determining what parts to order to solve this problem. The washer ran fine for two loads, then during the third load several things went wrong. Noticed a strong odor of rubber, and saw that the machine was spinning slowly but still had a lot of water in it and water was leaking on the floor from the edges of the cabinet. It was almost done with the cycle and shut off. I pulled the front panel and saw water dripping out of the tub where the transmission shaft enters. I siphoned about 6 gallons out (to the bottom of the inside tub) and the dripping stopped. I lowered the drain hose to dump the rest of the water and it drained fine. I looked under and the belts still looked ok and it seems like the pump turns ok when I turn the motor pully. The inside of the cabinet has some signs of oil splatter that flung off of the transmission.
I assume I need the tub seal and the bearing, and belts just to be sure. Why didn't the water pump out? Do I need a pump or is it something else? Can water leak into the transmission or is it still OK (it has never made any bad noises). Where can I get the instructions on how to replace the seal on the tub?
Thank you for your assistance - Kurtis
wapanstore
#2 Posted : Monday, February 20, 2012 8:19:44 PM(UTC)
wapanstore
What could be causing my Maytag washer to leak water?
Laser pointer
applianceman
#3 Posted : Tuesday, February 21, 2012 7:27:12 AM(UTC)
applianceman
This page should help
Maytag Tub Seal Replacement
Maytag washer leaking (Washer Repair)
by kpks26 2/5/2014 1:16:48 PM(UTC)
Maytag Washer Leaking (Washer Repair)
by scottlassy 12/11/2012 7:46:32 PM(UTC)
Maytag Washer Leaking Water into Tub (Washer Repair)
by mightypasta 11/21/2011 8:55:22 AM(UTC)
maytag washer leaking and overflowing (Washer Repair)
by bennettelliott 9/4/2010 11:02:54 AM(UTC)
maytag washer leaking (Washer Repair)
by mailmandennis 7/23/2010 8:11:46 AM(UTC)
Maytag washer leaking from bottom (Washer Repair)
by Famof5 7/8/2010 5:29:47 PM(UTC)
Maytag washer leaking, Seems to come from Pump (Washer Repair)
by mikou 11/11/2009 11:04:33 AM(UTC)
Maytag washer leaking only on delicate cycle (Washer Repair)
by bsly58 6/6/2009 5:58:01 PM(UTC)
