nascaral
#1 Posted : Sunday, July 26, 2009 12:42:42 PM(UTC)
nascaral
Hi
I have a frigidaire washer that overflows when it runs the fill and rinse cycles.I tried changing the temps and load size and it still over flows.The water still runs even if i turn off the washer.Can someone please help me out so I do not have to buy a new washer.
sidfink43
#2 Posted : Monday, July 27, 2009 6:00:59 AM(UTC)
sidfink43
This is the likely situation, given we do not have a model number.
Good news: No way you need to buy a new washer.
If the water stays on even after you turn off the washer, the valves are stuck open, and you need to replace them. A pretty easy and inexpensive job.
If the water stops flow after you shut off the machine, the problem is likely in your water pressure system. First make sure the plastic tube that powers the pressure switch is clear. If it is, and the problem persists, you will need to change out the water pressure switch. A pretty easy and inexpensive job.
If neither or these fix it, re post and tell us what you found out.
If you need more info please post your full model number.
nascaral
#3 Posted : Tuesday, August 4, 2009 2:52:29 PM(UTC)
nascaral
Originally Posted by: nascaral Go to Quoted Post
Hi
Hi
I want to thank you for your advise.I changed the valve and everything works fine again.The $45.00 part saved me hundreds.Thanks again and I will be sure to tell everyone about your web site.
Thanks,Al
sidfink43
#4 Posted : Tuesday, August 4, 2009 3:08:58 PM(UTC)
sidfink43
Nice going! And thanks for updating us. Really glad that worked!
washer over flows and will not agitate (Washer Repair)
by nick baumann 4/21/2009 7:09:34 AM(UTC)
Washer over flows on rinse last cycle (Washer Repair)
by wejohns1 2/3/2009 6:20:24 PM(UTC)
