My washer over flows on the rinse cycle every now and then (about every 4 or 5 loads). I called a repairman and he replaced the water level switch. Still does it. Could it be the timer sticking which causes the washer to continue to fill to over flowing? I noticed this time around it was stopped on the last rinse cycle. Any suggestions on what could be causing it?
Select Cold/Cold. Turn the machine on. Unplug it as it is filling. If it continues to fill while unplugged, the water inlet valve is the culprit.
