berniefl
#1 Posted : 16 years ago
berniefl
I'm not sure if I have one problem or two. My Whirlpool dryer seems to runs fine, but it has no heat in any cycle. The timer does not advance in any cycle as well, and dryer continues to run. Thanks for any help and insight.
sidfink43
#2 Posted : 16 years ago
sidfink43
Hi Bern
Let's see if we can fix your heating problem and then see if you still have the timer problem. You will need an electrical meter to troubleshoot, and here's what I suggest you do.
1. Check to make sure you have 120 volts to each side of the connection block.
2. Then unplug the dryer and take off the back and test the thermal fuses/thermostats for continuity.
3. If they check out, test the heating element for continuity, ohms (between 12 and 20 usually) and see that it is not broken or grounded.
One of these should fix you up.
Good luck, let us know if you need more info.
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 4 years ago
Cabrio dryer problems (Dryer Repair)
by artsalena 8 years ago
GE dryer problems (Dryer Repair)
by js072384 13 years ago
Dryer Problems (Dryer Repair)
by smartin349 13 years ago
by Mickey_951 14 years ago
by Tsailor 14 years ago
Dryer problems (Dryer Repair)
by Shoopes 15 years ago
by talbot 15 years ago
Asko condenser dryer problems (Dryer Repair)
by Marv Sumner 16 years ago
Dryer problems mikeo (Dryer Repair)
by mikeo1899 16 years ago
Dryer problems HELP (Dryer Repair)
by MizzJessica 16 years ago
by mbgrdido 16 years ago
by janezucker 16 years ago
Roper Dryer problems (Dryer Repair)
by b0001744 17 years ago
by Myles.Smith 17 years ago
