Hi there !
We own a Amana Fridge .It seems that the freezer has stopped working . I am wondering if the freezer and fridge work off the cam components? If I turn the freezer off will it shut the fridge off ?
What part do you think we will need ? :confused:
The fan is still running in the back the fridge seems to be cold but the freezer is not working ... The little red knob on the bottom right when you turn it, it clicks in for a moment but then seems that a fan is going but not freezing .....:confused:
Quote:...check if the compressor and the fan next to it are running. Check if the fan inside the freezer is running... What about these parts? Gene.
Originally Posted by: Gene What about these parts?
Gene. The fan in the freezer is running !!!!!!!! I will check the compressor....... What kind of sound should it be making ?
Originally Posted by: Starr1126 The fan in the freezer is running !!!!!!!! I will check the compressor....... What kind of sound should it be making ? I really dont know if it is running ??? The fridge seems to be running no stop......... like the fans .....seem too run nonstop
Is the compressor warm or hot on touch? Does it vibrate?
