Starr1126
#1 Posted : Thursday, July 23, 2009 9:31:02 AM(UTC)
Starr1126
Hi there !
We own a Amana Fridge .It seems that the freezer has stopped working . I am wondering if the freezer and fridge work off the cam components? If I turn the freezer off will it shut the fridge off ?
What part do you think we will need ?
:confused:
#2 Posted : Thursday, July 23, 2009 4:02:35 PM(UTC)
Remove the cover on the back of the refrigerator and check if the compressor and the fan next to it are running. Check if the fan inside the freezer is running. Post the results.
Here are the breakdown diagrams and Replacement parts for AMANA BR18VC | AppliancePartsPros.com
Starr1126
#3 Posted : Thursday, July 23, 2009 5:07:53 PM(UTC)
Starr1126
The fan is still running in the back
the fridge seems to be cold but the freezer is not working ... The little red knob on the bottom right when you turn it, it clicks in for a moment but then seems that a fan is going but not freezing .....:confused:
#4 Posted : Thursday, July 23, 2009 5:11:15 PM(UTC)
Quote:
...check if the compressor and the fan next to it are running. Check if the fan inside the freezer is running...
What about these parts?
Starr1126
#5 Posted : Thursday, July 23, 2009 5:19:27 PM(UTC)
Starr1126
The fan in the freezer is running !!!!!!!! I will check the compressor....... What kind of sound should it be making ?
Starr1126
#6 Posted : Thursday, July 23, 2009 5:32:02 PM(UTC)
Starr1126
I really dont know if it is running ??? The fridge seems to be running no stop......... like the fans .....seem too run nonstop
#7 Posted : Friday, July 24, 2009 11:33:02 AM(UTC)
Is the compressor warm or hot on touch? Does it vibrate?
