AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Frigidaire Affinity Washer Water Valve Harness Locking Plugs
I ordered the replacement part for the water valve/Dispenser/NTC/Short Tube. There are three locking plugs in the water valve harness that connect to part I need to replace. I've found the repair manual online, and it simply notes that these are locking plugs. I can see that there is a small ridge that is part of the locking mechanism, but even after lifting the plug away from that ridge, these three plugs do not want to come off. I'm hesitant to apply too much force trying to remove them. Does anyone know if there is a "trick" to disconnecting the locking plugs from the part so that I can replace the part? rickden attached the following image(s):
frigidaire water valve is stripped and needs to be replaced. How do i take off the back? The model is -fleb8200dso
It's a frigidaire washer model-fleb8200dso and it's a small hole. And it's not comimng out.
Originally Posted by: sadsack It's a frigidaire washer model-fleb8200dso and it's a small hole in the back of the washer. It icomes out a little but not all the way. Do i continue to try to pull it
Originally Posted by: sadsack Originally Posted by: sadsack It's a frigidaire washer model-fleb8200dso and it's a small hole in the back of the washer. It icomes out a little but not all the way. Do i continue to try to pull it There are no screws in the back to take off. So how do i get it out?
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Washer Repair
