JDouglas
#1 Posted : Wednesday, July 22, 2009 2:17:24 PM(UTC)
JDouglas
I just boughte replacement water valve and the new one has push in connections for water lines and old one had screw on connectors. How do I make new one work??
woodchuckie
#2 Posted : Wednesday, July 22, 2009 2:42:04 PM(UTC)
woodchuckie
Just cut the threaded ends off and insert into new valve. Depress the ring to get it back out.
JDouglas
#3 Posted : Wednesday, July 22, 2009 2:46:37 PM(UTC)
JDouglas
the water lines from fridge are the ones with the threaded nut, if i cut it off then what will keep it from leaking? also the water lines have a pointed tip.
woodchuckie
#4 Posted : Wednesday, July 22, 2009 5:01:20 PM(UTC)
woodchuckie
The new valve has the new quick release type connectors and it will seal when you push the cut off tube into it firmly.
How to pull microwave out of mw/oven combo (Oven Repair (including Ranges and Cooktops))
by cromking 5/6/2024 1:13:05 PM(UTC)
GE XL44 oven woes: temp knob fell out, how to remove cover? (Oven Repair (including Ranges and Cooktops))
by cyberdingo 4/29/2024 8:32:15 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
how to determine if kenmore ice dispenser is bad (Oven Repair (including Ranges and Cooktops))
by Guest 7/6/2023 3:32:28 PM(UTC)
Maytag Model MFI2269DRM00 - How to Teigger Ice Maker Water (Refrigerator & Freezer Repair)
by Vettenuts 5/16/2023 5:13:24 AM(UTC)
How to Access Refrigerant Line in Back of Fridge (Refrigerator & Freezer Repair)
by lothian.mcadam 4/27/2023 7:30:32 AM(UTC)
How to diagnose Thermador gas oven PG366BS not heating? (Oven Repair (including Ranges and Cooktops))
by Guest 4/12/2023 12:28:01 PM(UTC)
How to remove the sticky screws in GE cooktop? (Oven Repair (including Ranges and Cooktops))
by Guest 4/9/2023 10:34:15 AM(UTC)
How to test a direct-drive transmission? (Washer Repair)
by DIY_Again! 3/20/2023 9:12:52 AM(UTC)
How to use lie detector (Dishwasher Repair)
by remingtonjames 3/6/2023 2:43:38 AM(UTC)
Bosch AXXIS dryer - how to replace blower belt?? (Dryer Repair)
by Guest 1/5/2023 3:41:46 PM(UTC)
How to start manual defrost 18yr old kitchen air refrigerator (Refrigerator & Freezer Repair)
by brianappj 11/17/2022 7:47:58 AM(UTC)
How to fix a EO F1 error code (Oven Repair (including Ranges and Cooktops))
by Guest 10/16/2022 10:15:19 AM(UTC)
Bosch Dishwasher SHX68T55UC/02 Leak Identified: How to Fix? (Dishwasher Repair)
by jonneytaee 8/31/2022 4:48:51 AM(UTC)
How to remove PCB Assembly - LG Top Load Washer WT7600HKA (Washer Repair)
by cporantes 7/4/2022 8:38:27 AM(UTC)
