jjab500
#1 Posted : Tuesday, July 21, 2009 8:56:34 AM(UTC)
jjab500
2 wks. ago my 1 yr. old washer quit aggitating after filling. It would not advance unless I closed the lid firmly. Then it stopped working on all cycles except regular. I could hear ticking, like it was getting power, but would not work. Now, it wont work at all.
I checked all of the eassy stuff, the plug, circ.breaker, etc. I am good at repairs, but don't know where to start on this one.
Thanks, Julie
sidfink43
#2 Posted : Tuesday, July 21, 2009 3:41:42 PM(UTC)
sidfink43
Hi Julie
Since your machine is relatively new, there should not be a mechanical or electrical problem, but your symptoms suggest one. I would first check out the drain pump and line to make sure nothing is clogging it. The next thing to check is the connection to the timer. Then check the lid switch, which may be the problem since it did operate when you closed hard.
If all this fails to solve it you may be looking at replacing the timer.
Good luck
Whirpool washer will not spin (Washer Repair)
by Guest 1/27/2022 11:02:31 AM(UTC)
Whirpool Washer hums but does not spin (Washer Repair)
by markob 6/27/2014 7:20:54 AM(UTC)
Whirpool washer agitates but wont drain or spin (Washer Repair)
by kmsimpso 5/10/2014 9:17:09 AM(UTC)
Whirpool Washer - need help! (Washer Repair)
by jbrixey1@hotmail.com 3/31/2014 5:57:44 AM(UTC)
Whirpool washer making whirring noise (Washer Repair)
by junksasa 6/4/2013 7:18:47 AM(UTC)
whirpool washer stopped at rinse cycle and wont drian or spin (Washer Repair)
by janie527 6/1/2013 4:04:39 PM(UTC)
Whirpool washer won't drain, makes grinding noise (Washer Repair)
by coldbeerchief 1/7/2013 8:40:06 PM(UTC)
Whirpool Washer not aggitating/Spinning (Washer Repair)
by Cielo 10/24/2012 8:48:29 AM(UTC)
Whirpool washer not spinning, desperately need your help please (Washer Repair)
by dro53 9/16/2012 10:41:49 AM(UTC)
Whirpool Washer Will No Go To Rinse Cycle (Washer Repair)
by roperstopper 9/7/2012 7:07:09 AM(UTC)
Whirpool Washer - Clothes Wet After Spin (Washer Repair)
by lester100 7/17/2012 10:59:12 AM(UTC)
whirpool washer fills but wont shut off (Washer Repair)
by pete1949 6/29/2012 11:57:43 AM(UTC)
whirpool washer will agitate but will not spin (Washer Repair)
by Menard70506 6/1/2012 11:57:33 AM(UTC)
Whirpool washer Ultimate care 11 won't rinse or spin (Washer Repair)
by rckrhea2010 2/21/2012 4:41:04 PM(UTC)
Whirpool washer not working (Washer Repair)
by Chicago3110 2/1/2012 12:37:17 PM(UTC)
