btd
#1 Posted : 17 years ago
btd
After replacing upper spray arm assembly arm still does not rotate. Should I now rebuild pump?
#2 Posted : 17 years ago
Is it enough water to create sufficient pressure in the wash system?
Is the delivery tube for the upper spray arm installed properly?
misterfixall
#3 Posted : 17 years ago
misterfixall
is lower spray arm rotating normaly? . often dishes are not beeing rinsed off before being put in d/w, sump screen can be blocked up with food particles preventing normal water pressure from entering tub to spray arms
Bearboog
#4 Posted : 16 years ago
Bearboog
I have the same question. On my unit, the screen is clear, and neither spray arm is clogged with calcium buildup. The lower arm seems to be rotating normally.
#5 Posted : 16 years ago
This is a duplicated thread.
Answered here: http://forum.appliancepartspros...129-upper-spray-arm.html
