btd
#1 Posted : Friday, January 4, 2008 9:24:53 AM(UTC)
btd
After replacing upper spray arm assembly arm still does not rotate. Should I now rebuild pump?
#2 Posted : Friday, January 4, 2008 4:41:03 PM(UTC)
Is it enough water to create sufficient pressure in the wash system?
Is the delivery tube for the upper spray arm installed properly?
misterfixall
#3 Posted : Friday, January 4, 2008 7:31:28 PM(UTC)
misterfixall
is lower spray arm rotating normaly? . often dishes are not beeing rinsed off before being put in d/w, sump screen can be blocked up with food particles preventing normal water pressure from entering tub to spray arms
Bearboog
#4 Posted : Tuesday, June 23, 2009 3:46:36 PM(UTC)
Bearboog
I have the same question. On my unit, the screen is clear, and neither spray arm is clogged with calcium buildup. The lower arm seems to be rotating normally.
#5 Posted : Wednesday, June 24, 2009 7:08:47 PM(UTC)
This is a duplicated thread.
Answered here: http://forum.appliancepartspros...129-upper-spray-arm.html
Guest (4)
