christian1959
#1 Posted : Tuesday, July 21, 2009 3:19:41 AM(UTC)
christian1959
My dryer does not heat. The igniter glows for a few seconds and then goes out. I ordered the gas valve coils (Solenoid Kit), but was informed it does not come with directions.
1. I think I need to remove the drum. Does this only involve removing the belt
from the pulley?
2. Do I need to shut off the gas valve? If so, can I shut off the valve outside the
dryer that is on the basement wall? If I need to shut off the valve inside the
dryer, I need instructions as to what it looks like, where it is and how to turn it,
including what tool to use. Do I need to test for gas leak when I turn it back on?
3. Please provide directions for accessing, removing and replacing the solenoids.
I prefer to remove as few parts and screws as necessary. Hopefully, I won’t
need to touch the igniter, since that gray area is so sensitive. Do the Solenoids
simply pull out and push in by hand or do I need to use a needle nose pliers?
Thanks for the assistance.
#2 Posted : Tuesday, July 21, 2009 1:20:03 PM(UTC)
You can use the instructions from one of our previous posts: http://forum.appliancepartspros...ace-coils-gas-valve.html
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KGYS750GQ1 | AppliancePartsPros.com
