Dishwasher turns on and water does not fill. (Water is on) I checked the water float switch and it checks OK. Normally open, when float is down the switch is closed. I checked the valve connections (with power on during fill cycle) and there is not any power going to the valve. The service perpole here said there should be 120V present. Any suggestions??
