Mark B
#1 Posted : Friday, January 4, 2008 4:28:22 AM(UTC)
Mark B
I'm trying to verify the correct part for a problem I'm having with a Hotpoint (GE) side by side refrigerator with ice/water dispenser. The ice dispenser wouldn't work periodically and eventually stopped working. The water dispenser continued working for a short time and then stopped. Before each completely stopped working, I could jiggle the slide switches to get them to work. Now nothing works. The light still works with the switch, the light still comes on when depressing the dispenser pad, and the dispenser still clicks.
I thought the part I needed was the Control Board (part # AP2071638) but when speaking to the rep at AppliancePartsPros, she said if the light still worked, it was probably the Solenoid ASM (part # AP3672839). I thought the clicking meant the solenoid was not the problem.
Does anyone have a recommendation?
chris46
#2 Posted : Friday, January 4, 2008 6:26:20 AM(UTC)
chris46
after the ice comes out the door the little flap is stuck and wont close does the front panel come off so i can get to the flap easily ? its like the spring is stuck and wont let it shut
Ice/water dispenser panel removal -Kitchen Aid Superba 42 - KSSS42QDX05 (Refrigerator & Freezer Repair)
by gyusung1 4/15/2021 2:59:50 PM(UTC)
Ice/water dispenser trim removal -Kitchen Aid Superba 42 - KSSS42QDX05 (Refrigerator & Freezer Repair)
by gyusung1 4/2/2021 8:19:23 AM(UTC)
Sub Zero ice/water dispenser PCB switch (Refrigerator & Freezer Repair)
by Bob814 8/19/2019 5:42:32 AM(UTC)
GE Profile Arctica: ice/water dispenser panel dead (Refrigerator & Freezer Repair)
by Bogeyfreerfk 1/15/2016 1:07:28 PM(UTC)
GE Refrigerator Ice/water dispenser making horrible noise (Refrigerator & Freezer Repair)
by JRJACH75 5/6/2015 6:04:01 AM(UTC)
Maytag refrigerator ice/water dispenser very intermittent (Refrigerator & Freezer Repair)
by jstemper 3/21/2015 11:57:19 AM(UTC)
GE Side by Side Ice/Water Dispenser No Power and Temperature Control No Power (Refrigerator & Freezer Repair)
Belarus CAG8R 11/25/2014 5:45:35 AM(UTC)
Can't remove cradle assy on ge ice/water dispenser (Refrigerator & Freezer Repair)
by Pletch 12/11/2013 7:32:25 AM(UTC)
Replace spring(s) fridge ice/water dispenser (Refrigerator & Freezer Repair)
by jyhill 6/22/2013 1:07:24 PM(UTC)
Side by side whirlpool frig ice/water dispenser, light not working (Refrigerator & Freezer Repair)
by LenZ 3/7/2013 5:16:57 AM(UTC)
Front panel on ice/water dispenser (Refrigerator & Freezer Repair)
by rbtimperley 9/22/2012 5:55:05 AM(UTC)
Ice/water dispenser has stopped working (Refrigerator & Freezer Repair)
by Scott1973 8/9/2012 6:51:04 PM(UTC)
Maytag Ice/Water Dispenser Stopped Working (Refrigerator & Freezer Repair)
by Lori328 7/31/2012 3:49:25 AM(UTC)
In Door Ice/Water dispenser (Refrigerator & Freezer Repair)
by greyson1 6/18/2012 11:59:42 AM(UTC)
ice/water dispenser inoperative (Refrigerator & Freezer Repair)
by redrider 5/23/2012 9:25:11 AM(UTC)
