Every thing seems to work except the heat. How do I check to see if it is the element?
Unplug the dryer, move it away from the wall, take the back panel off. If you can see where the element goes you will need to remove the two wires attached to it. Then using the instructions at or near the top of the forum list use an ohm meter to see if the element is bad. (how to check for continuity)
