washer stopped working when i unplugged it to move to new house. power supply is good, push/pull switch works and lid switch is good, i pulled the control panel apart and check for some power and grounds based of of the supplied diagram and believe it is the water/temp control switch. my wife wants me to be sure by asking a expert, so here i am....lol any help would be appreciated!
It could be be the temp selection switch, but first move the timer to spin and see if it spins. That will show that power is getting to the timer and that the time is maybe ok. If it will spin, fill it with a hose and see if it will go into agitation. If it will then check out both the temp switch and the water level switches.
You may have to change them out, but if you buy from this site and the part is not needed or does not fix the problem you can return it, see the returns policy for details and conditions.
