tim
golferaz@gmail.com
#1 Posted : Thursday, July 2, 2009 2:43:22 PM(UTC)
golferaz@gmail.com
have a kenmore side by side refrigerator/freezer that the refrig side will not cool lower than 40o. The freezer side will go to 10o below. I replaced the temp sensor on the refrig side but still the same temp. I checked all passageways to and from the refrig side to the freezer, no blockages. I removed the cover for the cooling coils in the freeze and saw no ice or blockages. The fan for the freezer side is running but i am not sure it is pushing enough air into the refrig side. How can i check the fan motor to see if it is working properly?
I also noticed that the front/middle between the 2 doors really gets hot at times.
woodchuckie
#2 Posted : Thursday, July 2, 2009 6:31:26 PM(UTC)
woodchuckie
Make sure the condenser fan underneath the unit is running when the compressor runs.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Whirlpool Duet Sport wgd8300sw0 - drying time takes forever (Dryer Repair)
by mattyP4321 5/14/2024 8:34:23 AM(UTC)
GE dryer timer issue (Dryer Repair)
by Guest 5/8/2024 11:47:16 AM(UTC)
Whirlpool ler5635lq0 timer issue (Dryer Repair)
by Rolandtd 3/26/2024 6:15:44 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
GU2300XTVS0: Random pattern on lights & keypad sometimes no responsive [Quiet Partner III] (Dishwasher Repair)
by ocallau 3/3/2024 9:59:15 AM(UTC)
Frigidaire Affinity Washing Machine - Leaking only sometimes (Washer Repair)
by omf_24 2/24/2024 4:45:41 PM(UTC)
Hotpoint timer stalls in middle of opperation (Dishwasher Repair)
by Fidofax 2/15/2024 8:50:49 AM(UTC)
Dryer won’t stop after timer ends (Dryer Repair)
by ittssarah 2/4/2024 9:04:33 PM(UTC)
Clean light flashing 7 times: dishwasher run (Dishwasher Repair)
by Guest 1/14/2024 9:56:27 AM(UTC)
evaporator fan runs all the time in FF compartment (Refrigerator & Freezer Repair)
by Guest 8/17/2023 6:27:55 AM(UTC)
Kenmore 592-89032 Dryer POWERS OFF mid-cycle on both timer and moisture settings (Dryer Repair)
by Guest 7/15/2023 6:11:04 AM(UTC)
Alternate timer control for older Maytag top load washer ModelLAT8210AAW (Washer Repair)
by Guest 7/7/2023 12:43:57 PM(UTC)
Ice Maker Not Making Ice At All Times (Refrigerator & Freezer Repair)
by danrclem 6/11/2023 6:52:52 PM(UTC)
