Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I have the same issue. Clicks only on low ... so annoying! Any ideas would be welcomed!
Rank: Guest
I had the same problem as #10. Realized that I needed to rotate the diffuser (under he black plate so that it lines up with the igniter. Voila - fixed.
Rank: Guest
Mine ignite without the lighter once in awhile then I bought a new igniter module and replaced the old one. It work now but, new problem occurred. All 4 burners clicks when you ignite/lit one of the burners. I was wondering if anyone experienced similar issues or knows how to fix it. Thank you
Rank: Guest
Originally Posted by: Guest I have the same issue. Clicks only on low ... so annoying! Any ideas would be welcomed!
Same. Only on low.
Rank: Guest
If it clicks only on low, it’s likely that the flame gets too low for the flame detector. There is a procedure for adjusting the burner flame in the installation manual. It is NOT a really simple procedure. Requires pulling the top and then adjusting the venturi. Probably should also check that the jets are clean.
Rank: Guest
Originally Posted by: Guest Mine ignite without the lighter once in awhile then I bought a new igniter module and replaced the old one. It work now but, new problem occurred. All 4 burners clicks when you ignite/lit one of the burners. I was wondering if anyone experienced similar issues or knows how to fix it. Thank you I believe it’s normal for all of the igniters to spark when any of them spark. I don’t know that for certain, though. If they stop sparking when the flame starts, then all is ok.
Rank: Guest
I have all 4 clicking with just one burner on. Would appreciate any advice!
