2 Pages<12
Guest
#11 Posted : Wednesday, May 26, 2021 10:59:14 AM(UTC)
Guest
Rank: Guest
United States
I have the same issue. Clicks only on low ... so annoying!
Any ideas would be welcomed!
Guest
#12 Posted : Thursday, May 27, 2021 3:00:50 PM(UTC)
Guest
Rank: Guest
United States
I had the same problem as #10. Realized that I needed to rotate the diffuser (under he black plate so that it lines up with the igniter. Voila - fixed.
Guest
#13 Posted : Wednesday, July 21, 2021 11:34:29 PM(UTC)
Guest
Rank: Guest
United States
Mine ignite without the lighter once in awhile then I bought a new igniter module and replaced the old one. It work now but, new problem occurred. All 4 burners clicks when you ignite/lit one of the burners. I was wondering if anyone experienced similar issues or knows how to fix it. Thank you
Guest
#14 Posted : Monday, November 29, 2021 9:00:40 PM(UTC)
Guest
Rank: Guest
United States
Same. Only on low.
Guest
#15 Posted : Sunday, January 16, 2022 11:57:02 AM(UTC)
Guest
Rank: Guest
United States
If it clicks only on low, it’s likely that the flame gets too low for the flame detector. There is a procedure for adjusting the burner flame in the installation manual. It is NOT a really simple procedure. Requires pulling the top and then adjusting the venturi. Probably should also check that the jets are clean.
Guest
#16 Posted : Sunday, January 16, 2022 12:06:48 PM(UTC)
Guest
Rank: Guest
United States
I believe it’s normal for all of the igniters to spark when any of them spark. I don’t know that for certain, though. If they stop sparking when the flame starts, then all is ok.
Guest
#17 Posted : Sunday, July 17, 2022 3:22:20 PM(UTC)
Guest
Rank: Guest
United States
I have all 4 clicking with just one burner on. Would appreciate any advice!
Guest (5)
2 Pages<12
