clay cunliffe
#1 Posted : 16 years ago
clay cunliffe
ignitor glows but gas valve will not open. after glowing a short time I hear a click then ignitor will shut off and process repeats. could this be the flame sensor or is their other components that may cause this problem. wash machine was banging against dryer due to uneven load. Could that caused any of this problem.
#2 Posted : 16 years ago
This question was answered yesterday here: http://forum.appliancepartspros...821-haeting-problem.html
If you are not satisfied with this answer maybe somebody else on the forum can help you better.
clay cunliffe
#3 Posted : 16 years ago
clay cunliffe
replaced igniter and coil pack as you recommended. still have no flame. flame sensor ohm check was 84.6. igniter glows then clicks and shuts off then repeats. valves are not chattering any more since new coils were installed but still no flame. please help I have installed parts obove plus motor and belt. Im almost at the cost of a new dryer. In over my head on this one. I have to continue with repair at this piont.
#4 Posted : 16 years ago
This part is bad. No doubt about it.
clay cunliffe
#5 Posted : 16 years ago
clay cunliffe
gene sorry I made a mistake. the igniter ohm check was 84.6. the flame sensor was 00.5 at the terminals and I did have continuety between terminals.
#6 Posted : 16 years ago
Make sure the gas to the dryer is open.
Sometimes (very seldom) the flame sensor can be bad even it shows continuity.
If there is nothing wrong then the problem can be a bad gas valve.
Here are the breakdown diagrams and Replacement parts for MAYTAG PYG2300AWW | AppliancePartsPros.com
clay cunliffe
#7 Posted : 16 years ago
clay cunliffe
gene thanks for your help. your first suiggestion was right. I forgot to turn gas back on after replacing parts. you have been very helpful and thanks again for your time and helpful info.
#8 Posted : 16 years ago
I'm glad to hear you are back in business. Thank you for your feed back.
