ignitor glows but gas valve will not open. after glowing a short time I hear a click then ignitor will shut off and process repeats. could this be the flame sensor or is their other components that may cause this problem. wash machine was banging against dryer due to uneven load. Could that caused any of this problem.
replaced igniter and coil pack as you recommended. still have no flame. flame sensor ohm check was 84.6. igniter glows then clicks and shuts off then repeats. valves are not chattering any more since new coils were installed but still no flame. please help I have installed parts obove plus motor and belt. Im almost at the cost of a new dryer. In over my head on this one. I have to continue with repair at this piont.
Quote:flame sensor ohm check was 84.6 This part is bad. No doubt about it. Gene.
Originally Posted by: Gene  This part is bad. No doubt about it.
Gene. gene sorry I made a mistake. the igniter ohm check was 84.6. the flame sensor was 00.5 at the terminals and I did have continuety between terminals.
Originally Posted by: Gene  gene thanks for your help. your first suiggestion was right. I forgot to turn gas back on after replacing parts. you have been very helpful and thanks again for your time and helpful info.
I'm glad to hear you are back in business. Thank you for your feed back.
