Need To Know How To Manual Set The Defrost On. I Found The Circuit Board In The Back. I Know I Have A Defrost Problem. Just Want To Narrow It Down To Which Item It Might Be. Thanks For Any Help.
CORRECT MODEL NUMBER HSM25GFRA SA
ANYONe??
I just need to know if thier is any way of jumping the control board to start the defrost?
Originally Posted by: Gene  Thanks for the info. but quick question Gene. What is the color of the wire for the drfrost control. i am assuming i believe its the blue one. and then i test that with the orange one correct?
It is probably the blue wire, but I can not tell you exactly without the wiring diagram for this particular model. Also the defrost terminal on the control board should be marked.
