LAVOURA23
#1 Posted : Tuesday, June 30, 2009 5:58:14 AM(UTC)
LAVOURA23
Need To Know How To Manual Set The Defrost On. I Found The Circuit Board In The Back. I Know I Have A Defrost Problem. Just Want To Narrow It Down To Which Item It Might Be.
Thanks For Any Help.
CORRECT MODEL NUMBER HSM25GFRA SA
LAVOURA23
#2 Posted : Tuesday, June 30, 2009 7:24:24 AM(UTC)
LAVOURA23
ANYONe??
I just need to know if thier is any way of jumping the control board to start the defrost?
#3 Posted : Tuesday, June 30, 2009 12:16:44 PM(UTC)
The defrost cycle in your refrigerator controls by the main control board on the back of the refrigerator. You can not manually force it in the defrost but you do can test the defrost system parts.
You can find the instructions in one of our previous posts: http://forum.appliancepartspros...igerator-too-warm-3.html (the reply addressed to Bohemian).
Here are the breakdown diagrams and Replacement parts for GE HSM25GFRASA | AppliancePartsPros.com
LAVOURA23
#4 Posted : Tuesday, June 30, 2009 12:58:21 PM(UTC)
LAVOURA23
Thanks for the info. but quick question Gene. What is the color of the wire for the drfrost control. i am assuming i believe its the blue one. and then i test that with the orange one correct?
#5 Posted : Tuesday, June 30, 2009 6:51:44 PM(UTC)
It is probably the blue wire, but I can not tell you exactly without the wiring diagram for this particular model. Also the defrost terminal on the control board should be marked.
