I have a Maytag Gas range Model MGR4452BDW converted over to propane. The oven has gotten to where it will not come on occasionally or will not get above 200 degrees. What issues do I need to look for to fix this
Quote:What issues do I need to look for to fix this Your oven uses a hot surface (glow ignitor) ignition system. A start in narrowing down possible troublemakers will be observing what the oven ignitor is doing when the oven is malfunctioning. You can read about how common gas oven ignition systems work and the observations and tests necessary to diagnose problems with them at the following link: LINK > Understanding Gas Oven Ignition SystemsJFYI Dan O. www.Appliance411.com The Appliance Information Site=D~~~~~~
