skypilot01
#1 Posted : Monday, June 29, 2009 5:31:53 PM(UTC)
skypilot01
I have a Maytag Gas range Model MGR4452BDW converted over to propane. The oven has gotten to where it will not come on occasionally or will not get above 200 degrees. What issues do I need to look for to fix this
Dan O.
#2 Posted : Wednesday, July 1, 2009 9:05:55 PM(UTC)
Dan O.
Your oven uses a hot surface (glow ignitor) ignition system. A start in narrowing down possible troublemakers will be observing what the oven ignitor is doing when the oven is malfunctioning.
You can read about how common gas oven ignition systems work and the observations and tests necessary to diagnose problems with them at the following link:
LINK > Understanding Gas Oven Ignition Systems
JFYI
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
Oven will not get hot enough (Oven Repair (including Ranges and Cooktops))
by Racup 10/18/2014 6:07:00 PM(UTC)
oven will not get hot (Oven Repair (including Ranges and Cooktops))
by rich denison 2/18/2013 9:10:54 AM(UTC)
Hot Point/GE oven will not get hot (Oven Repair (including Ranges and Cooktops))
by jssncaz 10/5/2010 9:44:02 AM(UTC)
GE Range Oven will not get hot (Oven Repair (including Ranges and Cooktops))
by jlyrepair 9/22/2010 11:15:01 AM(UTC)
Whirlpool Oven will not get hot in bake but will broil (Oven Repair (including Ranges and Cooktops))
by 7faces 12/19/2008 1:31:48 PM(UTC)
