George1980
#1 Posted : Sunday, June 28, 2009 11:22:02 PM(UTC)
George1980
Even though its a frostless frig, I'm having frost covering the vents in the freezer, which I think is making the bottom of the frig not to cold. I'm thinking the problem is the defrost heater. I do not hear a hissing or sizzling sound or notice a red glow in the vents. Would this be the part I'm looking for to fix this problem , Thanks
woodchuckie
#2 Posted : Monday, June 29, 2009 7:49:53 AM(UTC)
woodchuckie
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
Part 23(f23) is your defrost timer. Replacement parts for FRG FRT18KG3CW2 | AppliancePartsPros.com
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does replace the timer. If it doesn't check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
SAMSUNG RF26J7500SR/AA - defrost heater testing (Refrigerator & Freezer Repair)
by curious99 3/30/2023 12:50:23 AM(UTC)
defrost heater not working but testing fine on multimeter (Refrigerator & Freezer Repair)
by doland 10/23/2022 11:10:02 PM(UTC)
Samsung Bottom Freezer Refrigerator Defrost Heater Replacement Part Help (Refrigerator & Freezer Repair)
by treefort 10/15/2022 11:51:27 AM(UTC)
Replacing the defrost heater, one bulb or two bulb heater? (Refrigerator & Freezer Repair)
by emilclintoc 7/12/2022 8:36:58 AM(UTC)
Defrost heater for very old Sears Coldspot 106.7627410 (Refrigerator & Freezer Repair)
by kboyette 3/20/2022 3:31:17 PM(UTC)
No power to defrost heater during forced defrost mode (Kenmore Elite) (Refrigerator & Freezer Repair)
by skssf 10/2/2020 12:37:01 PM(UTC)
How To Cycle Defrost Heater On Freezer (Refrigerator & Freezer Repair)
by DavyP49 7/20/2020 11:50:45 AM(UTC)
Defrost heater question (Refrigerator & Freezer Repair)
by phildonnia 8/21/2019 4:22:04 PM(UTC)
Defrost Heater always On. (Refrigerator & Freezer Repair)
by peterwapel 8/9/2018 9:12:01 AM(UTC)
Defrost Heater (Refrigerator & Freezer Repair)
by mokalan 7/9/2018 7:18:13 AM(UTC)
Defrost heater burning evaporator cover side gasket (Refrigerator & Freezer Repair)
by bahoefs59 3/31/2018 9:05:43 AM(UTC)
Correct Readings for Thermostat/Defrost Heater (Refrigerator & Freezer Repair)
by willjohnston 5/19/2017 8:15:57 AM(UTC)
Problem with Defrost Heater (Refrigerator & Freezer Repair)
by edkress 3/12/2017 1:24:53 PM(UTC)
Defrost heater and thermostat (Refrigerator & Freezer Repair)
by Servicer123456 10/30/2016 8:05:46 AM(UTC)
Defrost heater stays on during cooling cycle (Refrigerator & Freezer Repair)
by ragpicker 6/4/2015 5:54:06 PM(UTC)
